BUG
ArcMap crashes when attempting to convert labels to annotation
** This issue is addressed in ArcGIS 9.0 Service Pack 2 (SP2).
Click on the link in Related Information below and download Service Pack 2, if necessary. **
ArcMap may crash when converting labels from label classes symbolized with label marker symbols to annotation. This occurs with annotation in the map or in a geodatabase.
Cause
This is a known issue.
Workaround
If the Service Pack 2 is unavailable, work around this issue by creating the labels without the marker symbols and convert them to annotation. The annotation can then be edited to apply the marker symbols as needed.
    Article ID:000007144
    Software:
    • ArcMap 9 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
