English
How To: Copy an ArcSDE embedded raster catalog to a new user using ArcObjects
Summary
Instructions provided describe how to copy and paste an ArcSDE embedded raster catalog to a new using ArcObjects.
Procedure
  1. Start ArcMap.
  2. Create a new UIButtonControl: How To: Create a new UIButtonControl​
    For more information on creating a UIControl, see the ArcGIS Desktop Help topic: 'Creating custom commands with VBA and UI Controls'
  3. Right-click the UIButtonControl and select View Source.
  4. Copy this code into the UIButtonControl's click event. Modify the connection properties to reflect the settings of the database being connected to.
    Code:
    Dim pCat As IRasterCatalogTable
        Dim pws As IFeatureWorkspace
        Dim pRaster As IRaster
        Dim i As Integer
        Set pws = open_workspace("myserver", "5151", "", "user1", "user2")
        Set pCat = open_sde_rastercatalog(pws, "oldcat")
        For i = 0 To pCat.size - 1
            Set pRaster = pCat.RasterDataset(pCat.OID(i)).CreateDefaultRaster
            If i > 0 Then flag = True
            LoadToSDE pRaster, "myserver", "5151", "", "user2", "user2", "copycat"
        Next i
  5. Copy this code above the UIButtonControl's click event.
    Code:
    Dim flag As Boolean
  6. Copy this code below the UIButtonControl's click event.
    Code:
    Public Sub LoadToSDE(pRaster As IRasterProps, sServer As String, sInstance As String, _
                         sDB As String, sUser As String, sPasswd As String, sSDERaster As String)
        ' sDir: the directory where the input raster resides
        ' sInput: the name of input raster
        ' sServer,sInstance,sDB,sUser,sPasswd: ArcSDE connection info
        ' sSDERaster: the output ArcSDE raster dataset name
        Dim pSDEConn As IRasterSdeConnection2
        Dim pSDEStorage As IRasterSdeStorage2
        Dim pSDEOp As IRasterSdeServerOperation2
        Dim pRasterWsFact As IWorkspaceFactory
        Dim pRasterWs As IRasterWorkspace
        Dim pGeoDs As IGeoDataset
        Dim pCat As IRasterSdeCatalog
        ' Initialize RasterSDELoader
        Set pSDEConn = New RasterSdeLoader
        Set pCat = pSDEConn
        ' Make connection
        pSDEConn.ServerName = sServer
        pSDEConn.Instance = sInstance
        pSDEConn.Database = sDB
        pSDEConn.UserName = sUser
        pSDEConn.Password = sPasswd
        Set pSDEConn.Raster = pRaster
        pSDEConn.SdeRasterName = sSDERaster
        ' Set storage parameters
        Set pSDEStorage = pSDEConn
        pCat.CatalogName = sSDERaster
        pCat.RasterName = "image"
        ' Set spatialreference
        Set pSDEStorage.SpatialReference = pRaster.SpatialReference
        ' Set tilesize
        pSDEStorage.TileHeight = 128
        pSDEStorage.TileWidth = 128
        ' Pyramids option
        pSDEStorage.PyramidOption = esriRasterSdePyramidDonotBuild
        ' keyword
        pSDEStorage.Keyword = ""
        ' Start loading
        Set pSDEOp = pSDEConn
        If Not flag Then
           SDEOp.Create
        Else
           pSDEOp.Insert
        End If
        ' Cleanup
        Set pSDEConn = Nothing
        Set pSDEStorage = Nothing
        Set pSDEOp = Nothing
        Set pRasterWsFact = Nothing
        Set pRasterWs = Nothing
        Set pGeoDs = Nothing
    End Sub
    Function open_sde_rastercatalog(pws As IFeatureWorkspace, sTable As String) As IRasterCatalogTable
        ' Open a raster catalog table in an ArcSDE connection
        On Error Resume Next
        Dim pCatalogTable As IRasterCatalogTable
        Dim pTable As ITable
        Set pCatalogTable = New RasterCatalogTable
        If pws Is Nothing Then Exit Function
        ' Open table
        Set pTable = pws.OpenTable(sTable)
        ' Assign table to raster catalog
        Set pCatalogTable.Table = pTable
        ' Check if it is a raster catalog table
        If pCatalogTable.Table Is Nothing Then
           MsgBox sTable & " is not a raster catalog table"
           Exit Function
        End If
        pCatalogTable.Update
        Set open_sde_rastercatalog = pCatalogTable
        Set pCatalogTable = Nothing
        Set pTable = Nothing
    End Function
    Function open_workspace(sServer As String, sInstance As String, sDB As String, sUser As String, _
                            sPasswd As String) As IFeatureWorkspace
        ' Open a feature workspace using the input connection information
        Dim pFact As IWorkspaceFactory
        Dim pPropertySet As IPropertySet
        Set pFact = New SdeWorkspaceFactory
        Set pPropertySet = New PropertySet
        ' Populate connection property
        With pPropertySet
          .SetProperty "Server", sServer
          .SetProperty "Instance", sInstance
          .SetProperty "Database", sDB
          .SetProperty "user", sUser
          .SetProperty "password", sPasswd
          .SetProperty "version", "sde.DEFAULT"
        End With
        ' Open workspace
        Set open_workspace = pFact.Open(pPropertySet, 0)
        ' Clean up
        Set pFact = Nothing
        Set pPropertySet = Nothing
    End Function
