PROBLEM
When using the Novell NDPS type of print queues, the printer names can become quite long. Since ArcView has a limitation on the lengths of paths, starting ArcView may result in Segmentation Violation errors if these printers are set as the default.
The printer's name is too long or contains reserved characters.
Warning: The instructions below include making changes to essential parts of your operating system. It is recommended that you backup your operating system and files, including the registry, before proceeding. Consult with a qualified computer systems professional, if necessary. Esri cannot guarantee results from incorrect modifications while following these instructions; therefore, use caution and proceed at your own risk.
Get help from ArcGIS experts
Download the Esri Support App
