English
Error: Table not registered [user.raster] Invalid column value
Error Message
Attempting to load a raster to an SDE standalone raster dataset or existing raster catalog returns the following error:
"Failed to convert ...\raster.ext
Table not registered[user.raster]
Failed to execute (CopyRaster)"
Cause
Resampling techniques BILINEAR and CUBIC for an ArcSDE geodatabase are not supported for images with colormaps.
Solution or Workaround
Follow the solution below.
  1. Check Environments.. > Raster Geodatabase Settings > Resampling techniques for ArcSDE geodatabase
    If attempting to load a raster dataset with colormaps use the NEAREST resample technique.
