Frequently asked question
Does ArcGIS Desktop support Unicode?
Last Published: February 10, 2021
Answer
ArcGIS Desktop applications, such as ArcMap, are Unicode based, so they support Unicode to a certain level. The level of Unicode support depends on the data format.
Currently personal geodatabases and file geodatabases are the only data format that supports Unicode by default. It is even possible to store and display characters of multiple languages in a single personal or file geodatabase. If the characters are not displayed correctly, verify that the font is set to Unicode font, such as Tahoma.
Shapefiles also support Unicode, but not by default. To enable Unicode support in shapefiles, a registry key must be modified. See: How To: Read and write shapefile and dBASE files encoded in various code pages
Coverage and other legacy data formats do not support Unicode. Use geodatabases for these formats to store and display Unicode data.
Article ID:000007115
Software:
  • ArcMap 9 x
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
