English
Error: A selected item could not be added to the map
Error Message
While attempting to drag and drop a relationship class from ArcCatalog into ArcMap, the following warning is returned:
"A selected item could not be added to the map."
Cause
ArcMap does not support loading a relationship class as a data layer.
Solution or Workaround
This warning does not indicate that there is a problem with the relationship class. The functionality of a relationship class is always available when objects participating in that relationship class are loaded into ArcMap.
    Related Information
