ERROR
java.lang.IllegalStateException
Error Message
While making a request to an ArcWeb Service with Glue toolkit the following error message may appear:
"java.lang.IllegalStateException: Could not find method for proxy invocation.
Class class esri.arcwebservices.* was passed in. Please check that you are reading in map files."
Cause
The mapping files, or .map files under the WEB-INF/maps directory, were not read properly.
Solution or Workaround
Verify the location and permissions of the mapping files.
  1. Verify the mapping files are under the correct directory:
    .../WEB-INF/maps
    Verify the files have read permissions.
  2. If the problem is not corrected, Turn on Glue logging.
Article ID:000007067
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
