HOW TO
Note: This article pertains to ArcGIS versions 8.x and 9.x. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
Instructions provided describe how to apply a selection to a related table. In ArcMap, relates can be used to establish a relationship between feature classes and tables. Unlike joins, relates require a command to be issued before applying a tables selection to a related table. This example demonstrates how to programmatically apply a selection from a feature class to a related table in ArcMap using a relationship class.
Note: Support for Visual Basic for Applications (VBA) for ArcMap and ArcCatalog ended with the ArcGIS 10.2.2 release, and Esri has not included VBA compatibility setups since version 10.5. See: ArcGIS Desktop and VBA Moving Forward
The sample requires a feature layer in a geodatabase, participating in a relationship class with a standalone table to be loaded into a new ArcMap session. This relationship class must be created in the geodatabase using ArcCatalog; the code does not work properly on relationships created by right-clicking the layer in ArcMap and choosing 'Joins and Relates > Relate...'
Note: For more information on creating a UIControl, see the ArcGIS Desktop Help topic: 'Creating custom commands with VBA and UI Controls'
Note: This code is intended for use in ArcGIS Desktop 9.x. To run this in ArcGIS Desktop 8.x, it is necessary to change one line of code. Please see the comment toward the top of the "GetRelSelection" routine.
Private Sub GetSelection() Dim pDoc As IMxDocument Dim pMap As IMap Dim pFLayer As IFeatureLayer Dim pFClass As IFeatureClass Dim pFSelection As IFeatureSelection Dim pRelClassColl As IRelationshipClassCollection Dim pRelClass As IRelationshipClass Dim pEnumRelClass As IEnumRelationshipClass Dim pStandAloneTable As IStandaloneTable Dim pStandtabcollection As IStandaloneTableCollection Dim pTable As ITable Dim pInSelSet As ISelectionSet Dim pOutSelSet As ISelectionSet Dim pEnumRelationshipclass As IEnumRelationshipClass Dim pStTab As IStandaloneTable Dim pStTabColl As IStandaloneTableCollection Dim pRelationshipClass As IRelationshipClass Dim pDataset As IDataset Dim pOClass As IObjectClass Dim pTSelection As ITableSelection Dim pTabWin As ITableWindow 'Get the feature class from the map Set pDoc = ThisDocument Set pMap = pDoc.FocusMap Set pFLayer = pMap.Layer(0) Set pFClass = pFLayer.FeatureClass 'Get the relationship class from the featureclass Set pEnumRelationshipclass = pFClass.RelationshipClasses(esriRelRoleAny) Set pRelationshipClass = pEnumRelationshipclass.Next Set pOClass = pRelationshipClass.DestinationClass Set pTable = pOClass 'Get the selection set Set pFSelection = pFLayer Set pInSelSet = pFSelection.SelectionSet 'Get the selection set for the related table Set pOutSelSet = GetRelSelection(pInSelSet, pTable, pRelationshipClass) 'Get related table and add selection set Set pStTab = New StandaloneTable Set pStTab.Table = pTable Set pTSelection = pStTab Set pTSelection.SelectionSet = pOutSelSet Set pStTabColl = pMap pStTabColl.AddStandaloneTable pStTab pDoc.UpdateContents 'Create and open a new table window for the table Set pTabWin = New TableWindow Set pTabWin.Table = pStTab Set pTabWin.Application = Application pTabWin.UpdateSelection pOutSelSet pTabWin.ShowSelected = True pTabWin.Show True End Sub Private Function GetRelSelection(pFrSelSet As ISelectionSet, pToTable As ITable, pRelClass As IRelationshipClass) As ISelectionSet Dim pInSet As ISet Dim pOutSet As ISet Dim pCursor As ICursor Dim pRow As IRow Dim pOIDList() As Long Dim intOIDIndex As Integer Dim intCount As Integer Dim pOutSelSet As ISelectionSet Dim lngOID As Long ' Get the set of the selected rows ' NOTE: The following line of code is for 9.x installations. To make this work on 8.x, ' replace it with this line: ' Set pInSet = New esriCore.Set Set pInSet = New esriSystem.Set pFrSelSet.Search Nothing, False, pCursor Set pRow = pCursor.NextRow Do While Not pRow Is Nothing pInSet.Add pRow Set pRow = pCursor.NextRow Loop pInSet.Reset Debug.Print pInSet.Count 'Get the set of related rows and build an OID list Set pOutSet = pRelClass.GetObjectsRelatedToObjectSet(pInSet) If pOutSet.Count <> 0 Then Set pRow = pOutSet.Next ReDim pOIDList(pOutSet.Count - 1) intOIDIndex = pRow.Fields.FindField(pToTable.OIDFieldName) intCount = 0 Do While Not pRow Is Nothing pOIDList(intCount) = pRow.Value(intOIDIndex) Set pRow = pOutSet.Next intCount = intCount + 1 Loop End If 'Make a selectionset and add the OID's from the OID list - Option #1 Set pOutSelSet = pToTable.Select(Nothing, esriSelectionTypeHybrid, _ esriSelectionOptionEmpty, Nothing) If pOutSet.Count <> 0 Then For lngOID = 0 To pOutSet.Count - 1 pOutSelSet.Add (pOIDList(lngOID)) Next End If 'Make a selectionset and add the OID's from the OID list - Option #2 (uncomment to use and comment out Option #1) 'Dim pOutSelSet As ISelectionSet 'Set pOutSelSet = pToDispTab.DisplayTable.Select(Nothing, esriSelectionTypeHybrid, esriSelectionOptionEmpty, Nothing) 'pOutSelSet.AddList pOutSet.Count, pOIDList(0) Set GetRelSelection = pOutSelSet End Function
Get help from ArcGIS experts
Download the Esri Support App
