English
Error: Error installing software authorization
Error Message
When attempting to authorize ArcSDE 9.0 from the post-installation wizard or the sdesetup -o upgrade_key command this error may occur:
"Error installing software authorization"
Cause
The ArcSDE metadata repository must be upgraded from 8.x to 9.x before ArcSDE authorization.
Solution or Workaround
Upgrade the ArcSDE metadata repository to 9.x using one of two methods.
  • On Windows, click Start > Programs > ArcGIS > ArcSDE > ArcSDE Post Installation. Select the Custom option. Uncheck all the checkbox options except for Repository Setup and complete the wizard.
  • On Windows or Unix, run the sdesetup -o upgrade command. Details on this command are found in the ArcSDE Install Guide.
Related Information
