English
How To: Invert a surface with ArcGIS Spatial Analyst
Summary
Instructions provided describe how to invert a surface with ArcGIS Spatial Analyst. Inverting a surface will make the lowest cell the highest and vice versa.
Procedure
  1. Start ArcMap and add surface layer.
  2. Right-click on the surface layer and select Properties.
  3. Find the minimum and maximum value.
    These values will be needed for Step 4.
  4. Set the Extent and Cell Size to the surface layer in Spatial Analyst > Options.
  5. In the Raster Calculator type the following expression, substituting <maximum> and <minimum> with values from Step 2.
    Code:
    invert = (([elevgrd] - <maximum>) * -1) + <minimum>
