English
Error: AppName: arcmap.exe AppVer. 8.3.0.800 ModName: print.dll ModVer: 8.2.0.700 Offset: 00004e80
Error Message
The following Error Signature may be reported when ArcMap fails to start:
"AppName: arcmap.exe AppVer: 8.3.0.800 ModName: print.dll ModVer: 8.2.0.700 Offset: 00004e80"
Cause
The default printer or driver may be corrupt.
Solution or Workaround
Implement one of the following options to correct the problem:
  • Reinstall the default printer.
  • Set a different printer as the default printer.
  • Create a dummy printer and set it as the default printer. See the link in the Related Information section.
Related Information
