English
Problem: Construct tools on the annotation toolbar are disabled
The Construct tools on the Annotation toolbar do not enable after an editing session is started.
Cause
The annotation featureclass has not been updated from version 8.3 to version 9.0.
Solution or Workaround
To update the annotation featureclass, follow the procedure below.
  1. Start ArcMap.
  2. Go to Window > ToolBox.
  3. Expand Data Management Tools > Feature Class.
  4. Double-click Update Annotation Featureclass.
  5. Browse to and select the annotation feature class to be updated. Click OK.
