English
Bug: Buffer template for ArcGIS Server does not return results
When using multi-byte language, the Buffer template does return results.
Cause
The XML to Java API has not been internationalized yet.
Workaround
  1. Open the arcgis_webapps.properties file in a text editor. This file is in <ArcGIS Server Installation Directory>/DeveloperKit/Templates/Java/WEB-INF/classes.
  2. In the file, set the useXMLRecordSet property to false:
    useXMLRecordSet = false
  3. Save the file.
  4. Stop and restart the associated service.
