Summary
Instructions provided describe the steps to change the draw symbol for arcs in an ArcEdit session.
Procedure
The default lineset for ArcEdit is color.lin. This example changes the lineset to carto.lin, and calls a line symbol from that lineset file.
- Arcedit: editcover <cover_name>
Arcedit: editfeature arc
Arcedit: linedelete all
Arcedit: lineset carto.lin
Arcedit: symbolitem <cover_name> arc 210
Arcedit: drawenvironment arc
Arcedit: draw
The coverage arcs are drawn with linesymbol 210 from the lineset carto.lin. - The reference to the linesets provided with ArcInfo is found in the ArcDoc > Index tab. Type 'linesets', without quotes, and display the topic 'provided with ArcInfo'.
Active links allow you to display the available linesets, their symbols, and associated symbol numbers for use with the SYMBOLITEM command.
