ERROR
Output path does not exist: #
Error Message
When converting feature classes to geodatabase, and the path to the source data is over 2000 characters, an error will occur:
"Running script FeatureClassToGeodatabase...
Completed script FeatureClassToGeodatabase...
Failed to execute (FeatureClassToGeodatabase_6)."
Cause
Critical length of the multivalue is near 2000 characters. The sys.argv[1] line in featureClassConversion.py is not sufficient for strings of this length.
Solution or Workaround
Store the data in a path that is less than 2000 characters.
    Article ID:000007018
    Software:
    • ArcMap 9 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
