BUG
Python's ExportCAD command produces empty output
Writing a Python script for converting geodatabase layers, personal or SDE, to CAD produces empty output layers.
Cause
This is a known issue at ArcGIS 9.0
The ArcGIS Desktop Help provides examples of the syntax that should be used to write this code. The examples provided for this command contain typos. For example, the output type could be DXF_R14, however in the help, this is listed as DXF-R14, using a hyphen instead of an underscore.
Workaround
Change the syntax so that is uses DXF_R14 instead of DXF-R14
    Article ID:000007013
    Software:
    • ArcMap 9 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
