HOW TO
Convert DBASE (.dbf) to INFO
Last Published: March 5, 2021
Summary
This article pertains to ArcGIS versions 9.x only. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
Information provided describes how to convert a .dbf file to an INFO table using ArcMap.
Procedure
Choose one of the methods below.
Export the .dbf file
  1. Load the .dbf file into ArcMap.
  2. Right-click the .dbf file and select Open.
  3. Click the Options button and select Export.
  4. Browse to the location for the output. Within this browse window, change the file type to INFO.
  5. Click OK.
Use Arc Macro Language (AML)
Wrap an AML that calls the DBASEINFO command into a Python script and run it.
Article ID:000007004
Software:
  • ArcMap 8 x
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
