PROBLEM
ArcMap crashes when displaying labels
Last Published: April 26, 2020
Displaying labels for a feature class crashes ArcMap.
Cause
The feature class being labeled contains non-simple or invalid geometry.
Solution or Workaround
  1. Use the Repair Geometry tool located in ArcToolbox > Data Management Tools > Features > Repair Geometry to loop through all features and verify that the geometry is valid or simple.
  2. If the data is in shapefile format, recreate the spatial index in ArcCatalog. For more information, refer to the following Knowledge Base Article: How to: Build a spatial index for a shapefile.
    If the data is a geodatabase feature class, this step is not necessary. Geodatabase feature classes have spatial indexes by default.
Article ID:000006995
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
