ERROR
Attempts to delete a Relationship Class in ArcCatalog may result in the following error:
Code:
Delete Failed
Failed to delete selected object(s)
Insufficient permissions[
Locked by database user: '<username>' on machine: '<machine name>']
This error occurs under the following circumstances:
1. The owner of the relationship class does not own all of the related objects.
2. The owner of the relationship class has only SELECT privileges on the related objects that they do not own, but not UPDATE, INSERT, and DELETE.
Get help from ArcGIS experts
Download the Esri Support App
