BUG
Region to Polygon Coverage tool fails
The Region to Polygon Coverage tool fails to execute.
Cause
The Region to Polygon Coverage tool found by way of Coverage Tools > Data Management > Composite Features, uses the ArcGIS workstation engine and therefore the same functions as ArcGIS workstation. Workstation functions do not work if there is a space in the workstation internal workspace path. When ArcGIS is installed in the default location: c:\programs files\... the path contains a space and the tool does not work.
Workaround
The internal workspace path is defined as the system environment variable TEMP. To make this tool work navigate to the System properties dialog and change the 'TEMP' environment variable path to one with no spaces.
  1. Right-click My Computer and select properties.
  2. Click the Advanced tab.
    [O-Image] System Properties
  3. Click the Environment Variable button.
  4. Edit the 'TEMP' variable path.
    [O-Image] TEMP System Variable
  5. Select a location that has no space in the path; for example: C:\temp
Article ID:000006979
Software:
  • ArcMap 9 x
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
