BUG
After a custom geoprocessing environment setting has been created it appears as an option on the Environment Settings dialog. However, the metadata created for it does not appear on the environment settings dialog side-panel.
The functionality that allows metadata for custom environment settings to display in the environment settings dialog side-panel is not available in ArcGIS 9.0.
Get help from ArcGIS experts
Download the Esri Support App
