English
Bug: The WFS Connector requires HTTP version 1.0 with IIS and Tomcat
The WFS Connector only returns a valid response to GetFeatures requests when the web client uses HTTP version 1.0 when the WFS Connector is deployed with a configuration with IIS or Tomcat.
Cause
The cause is unknown.
Workaround
Any client that communicates with the WFS Connector that is using IIS or Tomcat in the configuration needs to be forced to use HTTP version 1.0.
  • An alternative solution is to configure the server with Sun ONE 6 (IPlanet) SP5 as the Web server instead of using IIS/Tomcat.
