English
FAQ: Can ArcSDE 8.3 raster layers be connected to from ArcIMS 4.0.1 with QFE Spatial Server Image Server Update or ArcIMS 9.0?
Question
Answer
Yes, a three tier connection using the ArcSDE server is possible.
There is one difference; for a vanilla ArcIMS 4.0.1 server, Administrator adds an AXL with raster name specified with mixed case in the DATASET tag.
Code:
<SDEWORKSPACE name="sde_ws-0" server="zephyr" instance="sde:oracle" database="TEST" user="FUN" encrypted="false" password="FUN" />
</WORKSPACES>
<LAYER type="image" name="hillshade" id="hillshade" visible="false" >
<DATASET name="FUN.hillshade.image" type = "image" workspace="sde_ws-0" />
However, if ArcIMS 4.0.1 is used with the latest ArcIMS 4.0.1 QFE Spatial Server - Image Server Update an error occurs.
[O-Image] Error
If an attempt to add the AXL file to Administrator in ArcIMS 9.0 the following returns:
[ERRO125] & [ERRO930].
To resolve this, specify the name in DATASET in uppercase.
Code:
</WORKSPACES>
<DATASET name="FUN.HILLSHADE.IMAGE" type = "image" workspace="sde_ws-0" />
For ArcIMS 9.0 the licensing has been changed so a Direct Connect to an ArcSDE 8.3 database cannot be used.
Upgrade ArcSDE 8.3 to 9.0 to verify these instructions work.
Related Information
