English
Error: [ERRO418] An error occurred in parsing the map configuration file. Document root element is missing
Error Message
When trying to create an ArcMap Image Service on Unix gives, the following error message is displayed in the Administrator Message Console:
"[ERRO418] An error occurred in parsing the map configuration file. Document root element is missing"
When logging out of Administrator and logging back in, the service appears as stopped. Starting the service does not yield any error messages.
Cause
This is a known issue that is found to occur when ServletExec AS version 5.0 is used in conjunction with the Apache web server and ArcIMS 9.x on Solaris.
Solution or Workaround
ServletExec has released a patch that addresses this issue. The patch can be downloaded from the link in the Related Information section below. Patch 'ServletExec_5_0p02' or greater is required. Consult the 'ReadMe.txt' on how to implement the patch.
If further assistance with the implementation of the patch is required, contact NewAtlanta Support. See Related Information section below
The version of Serlvet Exec 5.0 included on the ArcIMS installation CD, already contains this patch. ServletExec AS could also be re-installed using the version on the CD.
    Related Information
