English
Error: Warning: stream Length incorrect
Error Message
Opening ArcMap 9.0 PDF files in some applications, especially for the purpose of merging, produces an error or does not display the entire image stored in the PDF.
Cause
The PDF was created with the option Compress Vector Graphics turned ON. This is a known problem with ArcGIS 9.0.
Solution or Workaround
Turn Compress Vector Graphics to OFF and re-export the map.
  1. Click File / Export Map.
  2. Click Save as type drop down and select PDF (*.pdf).
  3. If the Options are not visible at the bottom, click the arrow button.
    [O-Image] ArcMap 9.x export options
  4. Click the Format tab.
  5. Click Compress Vector Graphics checkbox off.
  6. Click Save to proceed with export.
Related Information
