English
Error: Error opening feature class. Number of shapes does not match the number of table records
Error Message
Accessing or viewing a shapefile in ArcMap or ArcCatalog returns the error:
Error:
Cause
There is a mismatch between the number of features and the number of records in the DBF file.
This can be caused by editing the shapefile DBF table in Microsoft Excel.
This can also be caused by an ArcMap crash while the shapefile is being edited.
Solution or Workaround
The options listed below may fix the problem.
Warning:
Please be aware that third-party scripts and extensions are unsupported by Esri. It is highly recommended that a backup copy of the shapefile be created before running the damaged shapefile through either of these utilities.
  • Use the 'ShapeFile Repairer' utility available on ArcScripts to fix the mismatch. A link is provided in the Related Information section below.
    For the ShapeFile Repairer Utility to work correctly, ensure the language setting of the computer matches the language used to create the shapefile.
  • Use the 'Shapefile Repair Tool' by Jerry Workman. A link is provided in the Related Information section below.
  • Use ArcInfo Workstation to convert the shapefile to a coverage and back to a new shapefile using the following command sequence.
    Warning:
    This option is only available with the ArcGIS ArcInfo license with ArcInfo Workstation installed!
    Arc: precision double double
    Arc: usage shapearc
    Usage: SHAPEARC   {out_subclass}
         {DEFAULT | DEFINE}
    Arc: shapearc sample.shp tempcov
    Arc: build tempcov
    Arc: usage arcshape
    Usage: ARCSHAPE
         {DEFAULT | DEFINE}
    Arc: arcshape tempcov  newshape.shp
Related Information
