PROBLEM
When file based tables are used in joins, for example: <shapefile>.dbf, the joined table is dropped by ArcGIS Server Map Server or ArcIMS ArcMap Service on Solaris or Linux.
Paths to join tables are not updated correctly within the ArcMap document, when using the Set Data Source utility.
Joins that use ODBC connections on Windows are not supported by the ArcMap server on Unix.
Get help from ArcGIS experts
Download the Esri Support App
