English
FAQ: Can I automatically connect to the ArcWeb Toolbar 1.1 when opening ArcMap?
Question
Answer
When connected to ArcWeb Services with the ArcWeb Toolbar 1.1, the connection remains active for 12 hours, or until you disconnect. The connection remains active even if you close ArcMap unless you choose Disconnect from the ArcWeb Services menu.
Reconnect after each 12 hour period.
Related Information
