Frequently asked question
Can a compress operation be stopped or cancelled after it has been started?
Answer
The ArcSDE compress operation can be stopped or cancelled while it is executing. The operation is designed to be transactionally consistent. Implying if the operation encounters an error, fails or abruptly stops, the versioned tables being compressed are still 'logically' correct with respect to any version's representation. To stop or cancel the compress operation, refer to the Canceling a tool executing in the background section of ArcGIS Help: Foreground and background geoprocessing.
The compress operation first scans into memory the instance's state tree configuration. Based upon this information, the first step compress performs is to delete all states which do not participate within a version's lineage. The deletion of the state deletes all the rows from the delta tables that are associated with the state being deleted.
The next step the compress operation performs is to collapse any candidate lineage of states into one state. A candidate lineage is a collection of states that can be compressed into one state without affecting the logical representation for any table in a given version.
The final step, when applicable, is to move rows from the delta tables into the base tables.
For each step of the operation, database transactions are started and stopped for each table being compressed. The transaction verifies each table is consistent during each step of the process.
An example for stopping or cancelling a compress operation is, if the compress has been running for an extend period of time it might be preventing users from connecting to the instance, prior to ArcSDE release 9, or the compress operation is consuming a large amount of system resources.
Article ID:000006847
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
