English
FAQ: Does GET_SERVICE_INFO on an ArcMap Service return a projection ID?
Question
Answer
For ArcIMS version 9.1 (and newer versions), a GET_SERVICE_INFO request on an ArcMap Service returns both the projection string and id, unless the projection string has been modified in the map document. In that case, only the projection string is returned.
In prior versions, only the projection string is returned in response.
