PROBLEM
ArcToolbox tools do not start when double-clicked
When ArcToolbox tools are double-clicked, nothing happens or a brief hourglass appears.
Cause
Microsoft XML parser 3.0 Service Pack 4 (SP4) or XML Core Services 4.0 are not installed or have been removed since the installation of ArcGIS 9. This prevents the dialogs from being generated or displayed.
Solution or Workaround
Install the Microsoft XML Parser 3.0 SP4 and XML Core Services 4.0 from the links in the Related Information section below.
Even if the XML parser 3.0 and XML Core Services appear to be installed, rerun the install for both of these components; this will replace any files that may be missing or corrupt.
    Article ID:000006838
    Software:
    • ArcMap
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
