English
Bug: HTML Viewer returns null attribute values from joined table of ArcMap Service
Using the HTML Viewer, ArcMap Service features can be selected based on a buffer distance from features of another layer. There is an option to display the attribute values of these selected features.
In some instances, the values are empty for certain attributes.
Cause
If the selected features, based on the buffer, belong to a layer that is joined to a table, the values of the fields belonging to the joined table will not display.
Workaround
Though there is no workaround to display attribute values of a joined-table within the buffered features result table in the HTML Viewer, these values can be accessed using the HTML Viewer Identify tool. Identify correctly returns all attribute values.
Related Information
