English
Error: ld.so.1...No such file or database
Error Message
CONNECT on Solaris to Oracle 9i fails with the following error:
"Arc: connect oracle system/manager
ld.so.1: /arcexe83/bin/dbi_oracle9i: fatal: libclntsh.so.9.0:
open failed: No such file or directory
Server oracle, pid: 123 terminated abnormally".
Cause
The ArcInfo executable DBI_ORACLE9I is failing to find the Oracle library libclntsh.so.9.0, which is located in $ORACLE_HOME/lib.
Solution or Workaround
Add $ORACLE_HOME/lib to the system variable $LD_LIBRARY_PATH.
    Related Information
