English
Error: 0509-124 The program is a discontinued 64-bit object file.
Error Message
When installing ArcSDE 8.3 on AIX 5.1 / 5.2 with Oracle 9.2.0.3.0 / 9.2.0.4.0 [64-bit], users receive the following error while attempting to run the sdesetupora9i command:
"exec(): 0509-036 Cannot load program sdesetupora9i because of the following errors:
0509-124 The program is a discontinued 64-bit object file."
Cause
This version of ArcSDE requires a special installation CD that is not part of the standard ArcSDE 8.3 CD set.
Solution or Workaround
Contact ESRI Customer Service to obtain this special installation CD.
Part Number 94798.
    Related Information
