English
Error: Failed to update domain. The domain field type does not match that of the field it is being assigned to
Error Message
When trying to add a new subtype, the following error appears:
"Failed to update domain. The domain field type does not match that of the field it is being assigned to. [Name of Feature or Object Class]"
The error message may be appended with:
"Item not found in this collection"
Cause
One or more of the fields has an associated domain with a different field type. For example, the field may be a Short Integer while the domain is a Long Integer.
Solution or Workaround
The domain or field must be removed and recreated with the correct field type.
