English
Error: The dynamic link library orasql8.dll could not be found in the specified path
Error Message
Trying to CONNECT from ArcInfo Workstation 9.x on Windows to Oracle 9i produces the error message:
"The dynamic link library orasql8.dll could not be found in the specified path"
Cause
The CONNECT command is using the $ARCHOME/bin/dbi_oracle executable. By default this executable is programmed to use Oracle 8i libraries.
Solution or Workaround
Change the ORACLE.DBS file to reference a newer executable that is programmed to use Oracle 9i libraries.
<a href='http://support.esri.com/en/knowledgebase/techarticles/detail/26645' target='_blank'>How To: CONNECT to Oracle 9i on Windows using ArcInfo Workstation 9.0</a>
    Related Information
