English
Bug: Some administration commands fail on ArcSDE for Oracle 9i using direct connect on HP-UX and HP TRU64
** This issue has been addressed in ArcSDE 9.0 Service Pack 1 (SP1)**
The sde2shp, sde2tbl, sdeexport, sdeimport, shp2sde and tbl2sde ArcSDE administration commands fail on HP-UX and HP TRU64 if used with Oracle 9i and ArcSDE direct connect.
HP-UX fails with the following message:
"Segmentation fault (core dumped)"
HP TRU64 fails with the following message:
"Error: dlopen: <SDEHOME_path>/lib/libgsrvrora9i90.so: symbol "SES_pixel_read_1bit" unresolved Unable to create a connection on server <server_name>, for user <user_name>.SDE Code (-324): Server library could not be loaded."
Cause
This is a known issue.
Workaround
Click on the link in Related Information below to download the Service Pack, if necessary. **
Use a three-tiered application server connection by specifying the server name and ArcSDE service name or port number when using any of the following commands:
- sde2shp
- sde2tbl
- sdeexport
- sdeimport
- shp2sde
- tbl2sde
    Related Information
