English
Problem: The spatial reference for a geodatabase feature class is unknown after importing CAD data
The spatial reference for a geodatabase feature class is unknown after importing CAD data.
Cause
The CAD data that was imported into the geodatabase did not have a spatial reference.
Solution or Workaround
  • Define the spatial reference of the geodatabase feature class using ArcCatalog.
  • Define the spatial reference of the CAD data and re-import it into the geodatabase.
    Instructions for defining a coordinate system for CAD data can be found in the ArcGIS Help under Contents > ArcCatalog > Working with CAD data > Defining a coordinate system for CAD data.
Related Information
