BUG
Pie charts and legend patches with rounded corners are not drawn correctly
Pie charts in the ArcMap table of contents as well as legend patches with rounded corners in legends on the ArcMap layout are not drawn correctly.
When a layer is symbolized with pie charts, instead of seeing correct round lines for the outline of the pie chart in the table of contents, there are straight lines that cut across the chart.
When using legend patches with rounded corners, instead of seeing correctly rounded corners, there is a straight line that cuts across the legend patch.
Cause
The driver for the Windows graphic adapter is out-of-date.
Workaround
Upgrade the driver for the Windows graphic adapter.
  1. Open up the Windows Control Panel.
  2. Open the Display properties.
  3. Click Settings.
  4. Click Advanced.
  5. Click Adapter.
  6. Click Properties.
  7. Click Driver.
  8. Click Update Driver and follow the instructions.
Article ID:000006795
Software:
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
