HOW TO
Perform the spatial selection 'Share a line segment with' using ArcObjects
Summary
Instructions provided illustrate how to duplicate the functionality of ArcMap's spatial selection 'share a line segment with' through ArcObjects code.
Procedure
  1. Start ArcMap.
  2. Open the Visual Basic Editor.
    In ArcMap, select Tools > Macros > Visual Basic Editor.
  3. In the Project Explorer window, expand Project.mxt and select ArcMap Objects > ThisDocument. Right-click and select View Code.
    [O-Image] Visual Basic Project  Explorer
    Code in the Project's ThisDocument code module will only run in the current map document. If you want to store the code in all map documents open the Normal.mxt ThisDocument code module.
  4. Copy/Paste the following code into the code module.
    Code:
    Option Explicit
    Public Sub SelectPolyAsSharesSegementWith()
    Dim pMxDoc As IMxDocument
    Set pMxDoc = ThisDocument
    Dim pMap As IMap
    Set pMap = pMxDoc.FocusMap
    ' Union all of the search features into one geometry and strip off
    ' it's boundary for use in the search. Since we are only interested
    ' in shared segments, not areas, the boundary is all that is needed.
    ' Get search layer
    Dim pPolygonLyr As IFeatureLayer
    Set pPolygonLyr = pMap.Layer(1)
    Dim pLFeatClass As IFeatureClass
    Set pLFeatClass = pPolygonLyr.FeatureClass
    ' Loop through the polygons, simplify them and then
    ' add them to a Geometry Bag.
    Dim pFeatureCursor As IFeatureCursor
    Set pFeatureCursor = pLFeatClass.Search(Nothing, True)
    Dim pFeature As IFeature
    Set pFeature = pFeatureCursor.NextFeature
    Dim pGeometryCollection As IGeometryCollection
    Set pGeometryCollection = New GeometryBag
    Dim pTopologicalOperator2 As ITopologicalOperator2
    Do While Not pFeature Is Nothing
    Set pTopologicalOperator2 = pFeature.ShapeCopy
    pTopologicalOperator2.IsKnownSimple = False
    pTopologicalOperator2.Simplify
    pGeometryCollection.AddGeometry pTopologicalOperator2
    Loop
    ' Union all the polygons
    Dim pTopologicalOperator1 As ITopologicalOperator2
    Set pTopologicalOperator1 = New Polygon
    pTopologicalOperator1.ConstructUnion pGeometryCollection
    ' Construct the boundary of the unioned polygons
    Dim pTopologicalOperator3 As ITopologicalOperator2
    Set pTopologicalOperator3 = New Polyline
    Set pTopologicalOperator3 = pTopologicalOperator1.Boundary
    ' Use the boundary to find the candidate features
    ' Get the target FeatureClass
    Dim pFeatureLayer As IFeatureLayer
    Set pFeatureLayer = pMap.Layer(0)
    Dim pFeatureClass As IFeatureClass
    Set pFeatureClass = pFeatureLayer.FeatureClass
    ' Set up a scratch workspace to use for the selection
    Dim pScratchWorkspace As IWorkspace
    Dim pScratchWorkspaceFactory As IScratchWorkspaceFactory
    Set pScratchWorkspaceFactory = New ScratchWorkspaceFactory
    Set pScratchWorkspace = pScratchWorkspaceFactory.DefaultScratchWorkspace
    ' Setup the spatial filter
    Dim pSpatialFilter As ISpatialFilter
    Set pSpatialFilter = New SpatialFilter
    With pSpatialFilter
    Set .Geometry = pTopologicalOperator3
    .GeometryField = "SHAPE"
    .SpatialRel = esriSpatialRelIntersects
    End With
    ' Perform the search and create a selection set
    Dim pTempSelection As ISelectionSet
    Set pTempSelection = pFeatureClass.Select(pSpatialFilter, esriSelectionTypeIDSet, esriSelectionOptionNormal, pScratchWorkspace)
    ' Loop through the features and check to see if they share a segment
    ' with the search geometry. If they don't, remove them from the selection
    ' set.
    ' Create a feature cursor to allow us the examine the candidate features
    Dim pTempFeatCur As IFeatureCursor
    pTempSelection.Search Nothing, True, pTempFeatCur
    Dim iOIDList(1) As Long
    Dim iOIDListCount As Long
    iOIDListCount = 1
    Dim pGeometry As IPolyline
    Dim pTempFeat As IFeature
    ' Fetch the first feature
    Set pTempFeat = pTempFeatCur.NextFeature
    Dim pTempPolyline As IPolyline
    ' Check for the one dimentional intersection of the geometries.
    ' If there is no intersection the returned geometry will be empty. If
    ' it is, remove it from the selection set.
    Dim pTopologicalOperator4 As ITopologicalOperator2
    Set pTopologicalOperator4 = New Polygon
    Do
    iOIDList(0) = pTempFeat.OID
    Set pTopologicalOperator4 = pTempFeat.ShapeCopy
    pTopologicalOperator4.IsKnownSimple = False
    pTopologicalOperator4.Simplify
    Set pTempPolyline = pTopologicalOperator4.Boundary
    Set pGeometry = pTopologicalOperator3.Intersect(pTempPolyline, esriGeometry1Dimension)
    If pGeometry.IsEmpty Then
    pTempSelection.RemoveList iOIDListCount, iOIDList(0)
    End If
    Loop Until pTempFeat Is Nothing
    ' Set the feature selection
    Dim pFeatureSelection As IFeatureSelection
    Set pFeatureSelection = pFeatureLayer
    Set pFeatureSelection.SelectionSet = pTempSelection
    ' Display the selected features.
    Dim pdoc As IMxDocument
    Set pdoc = ThisDocument
    pdoc.ActiveView.Refresh
    End Sub
  5. Close the Visual Basic Editor.
  6. Run the code.
    A. Click Tools > Macros > Macros to display the Macros dialog box.
    B. Select a macro and click Run.
Article ID:000006784
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
