English
Error: Server Context creation failed on machine xxx. Access to output directory is denied
Error Message
When starting a server object the following error appears:
"Server Context creation failed on machine xxx. Access to output directory is denied."
Cause
The ArcGIS Server Object Container Account must have write permissions to the virtual directory.
The following is a sample directory: c:\inetpub\wwwroot\temp
Solution or Workaround
Follow the steps below.
  1. Right-click on the virtual directory, for example: c:\inetpub\wwwroot\temp
    Select the Properties > Security tab.
  2. Add the ArcGIS Server Object Container Account and give it write permissions, so that it can read/write images.
  3. Click OK to close the Properties dialog.
