ERROR
Access denied
Error Message
When trying to access http://localhost or http://127.0.0.1, the following message appears in the Web browser:
"Access denied"
Cause
This usually happens when IP address and domain name restrictions were setup in the Web server properties.
Solution or Workaround
  1. Open IIS Manager.
  2. Right-click on the Default Web Site and select Properties.
  3. Select the Directory Security tab. If restrictions were set, make sure there is an entry to explicitly grant access for 127.0.0.1 (localhost) or edit the list of denied machines as necessary.
  4. Click OK twice to close the Properties dialog.
Article ID:000006769
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
