BUG
Polygons stored in SDO_GEOMETRY with compound exterior boundaries with circular arcs fail Oracle Spatial validation
After creating a polygon in ArcMap that has a circular curve as part of the exterior boundary, Oracle’s SDO_GEOM.VALIDATE_LAYER_WITH_CONTEXT and other validation functions report that the exterior boundary is stored in incorrect rotation order. Specifically, the exterior boundary in these cases is a compound outer polygon (GTYPE 1005) with circular arcs.
Cause
This is a known issue.
Workaround
ArcGIS can still access and use these polygons.
    Article ID:000006756
    Software:
    • Legacy Products
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
