English
Error: A requested feature object could not be located
Error Message
When moving a junction feature, the following error message is returned:
"A requested feature object could not be located."
The error message may be appended with the feature class name of the feature that cannot be located.
Cause
The junction is connected to an edge feature which does not have an element ID (EID).
Solution or Workaround
Use the Rebuild Connectivity tool, the third button from the left on the Network Editing toolbar, to rebuild the connectivity of the junction and its coincident edges. Define an area that includes the junction and its coincident edges.
[O-Image] RebuildConnectivityArea
The Rebuild Connectivity tool will rebuild the connectivity of any network feature contained within or intersecting the defined area, including edges which do not have an EID.
