English
How To: Release a hung license from a remote License Manager server
Summary
Instructions provided describe how to remove a hung license from a remote License Manager server.
Procedure
If a physical or remote login access to the License Manager server cannot be obtained, a user account with administrative rights on that machine can use the following steps to release a hung license from a remote License Manager server.
  1. Install the ESRI License Manager on the local machine using the ArcGIS Desktop or ArcInfo Workstation installation CD.
    Since this will not be an active license manager a hardware key and license file is not required.
    <a href='http://support.esri.com/en/knowledgebase/techarticles/detail/19819' target='_blank'>How To: Create a dummy license file</a>
  2. Disable the License Manager service from starting automatically.
    Summary:
    Instructions provided describe how to disable the License Manager from automatically starting on Windows. The License Manager does not start automatically by default on UNIX.
    Procedure:
    The steps below refer to the License Manager installed with ArcGIS versions 8.x and 9.x.
    1. Start License Manager Tools.
      <div id='indent' style='padding: 0em,0em,0em,1em;'>ArcGIS 9.x:
      Navigate to Start > Programs > ArcGIS > License Manager (9.x) > License Manager Tools.
      ArcGIS 8.x:
      Navigate to Start > Programs > ArcGIS > License Manager > License Manager Tools.
  3. Select the 'Configuration using Services' radio button.
  4. Select the License Manager.
    <div id='indent' style='padding: 0em,0em,0em,1em;'>For ArcGIS 9.x:
    Highlight ArcGIS License Manager
    For ArcGIS 8.x:
    Highlight ESRI License Manager
  5. Select the 'Configure Services' tab.
  6. Uncheck 'Start Server at Power Up' and 'Use Services'.
    [O-Image] Disable Use Services
  7. Click 'Save Service' and 'Yes' to save the changes.
  • Navigate to the directory where License Manager is installed using the command line.
    Windows 8.x License Manager:
    Code:
    C:\> cd Program Files\ESRI\License
    Windows 9.0 License Manager:
    Code:
    C:\> cd Program Files\ESRI\License\arcgis9x
    UNIX:
    Code:
    UNIX% cd $ARCHOME/sysgen
    Hence forth, the Windows directory will be referred to as C:\Program Files\ESRI\License> and UNIX as UNIX%, regardless of version.
  • Obtain the information for the required fields of the lmremove command by running the license manager status command for the remote server.
    Code:
    C:\Program Files\ESRI\License> lmutil lmstat -a -c 27005@server1
    Example of the output from the lmutil lmstat command:
    Feature usage info:
    Users of ARC/INFO: (5 licenses available)
    JohnDoe client1 X:%#($1:0.0 (v8.01) (server1/27005 3180), start Wed 5/1/03 10:38
  • Check the output returned from the lmstat command to select the license you would like to release.
  • The proper syntax for the lmremove command is:
    Code:
    lmutil lmremove -h <feature> <host> <port@LM_Server> <handle>
    or
    Code:
    lmutil lmremove <feature> <user> <host> <display>
    The following information is an explanation of the syntax used in Step 6 and 7:
       Feature - ARC/INFO - This is the license that is hung.
    User - JohnDoe - The username of the person who checked out the license.
    Host - client1 - The hostname of the machine on which the license was being used.
    Port - 27005 - The port the license manager daemon is using to communicate.
    LM_Server - server1 - The hostname of the License Manager server.
    Handle - 3180 - A unique identifier for the license session.
  • Using the '-h <feature> <host> <port@LM_SERVER> <handle>' option:
    Code:
    %> lmutil lmremove -h ARC/INFO client1 27005@server1 3180
    Using the 'lmutil lmremove <feature> <user> <host> <display>' option:
    Code:
    lmutil lmremove -c license.dat ARC/INFO JohnDoe client1 X:%#($1:0.0
  • It is possible the display information is encrypted. Such is the case here:
       JohnDoe client1 1_)e4(aHzr|~ (v8.01) (server1/27005 3180), start Wed 5/1/03 10:38
    In such cases it is best to use the lmremove option '-h <feature> <host> <port@LM_Server> <handle>', unless the license manager is pre-ArcInfo 7.2.1 or pre-ArcView 3.1. When the display is encrypted, it may contain special characters, such as |, (,), ~, which will not be read for their text value. Use the double quotes when encountering such characters. For example:
    Code:
    lmutil lmremove -c license.dat ARC/INFO JohnDoe client1 "1_)e4(aHzr|~"
Related Information
