English
Bug: Setting filter after dynamically adding a layer sends a GET_IMAGE request instead of a GET_FEATURES request
If a Filter is set on a Feature Layer, ArcIMS Java Connector normally sends a GET_FEATURES request. However, if a layer is dynamically added to the map before applying the Filter object, it sends a GET_IMAGE request even though users are interested in getting attribute information and not a map image.
Cause
When a dynamic layer is added to the map, Java Connector sends a GET_IMAGE request.
Workaround
In order to force Java Connector to send a GET_FEATURES request, the dynamic layer must be removed.
  1. Add a dynamic layer:
    Code:
    ShapeWorkspace shpw = new ShapeWorkspace();
    map.addWorkspace(shpw);
    Dataset data = new Dataset();
    FeatureLayer fl = new FeatureLayer("topo", null, null);
    fl.setDataset(data);
    map.getLayers().add(fl);
  2. Apply the Filter object on the Feature layer:
    Code:
    Filter filter = new Filter();
    filter.setSpatialObject(envelope);
    fLayer = (FeatureLayer)map.getLayers().item(1);
    fLayer.setFilterObject(filter);
  3. Call Map.refresh() to trigger the request, note that the request is GET_IMAGE because of the existence of the dynamic layer:
    Code:
    map.refresh();
    mapURL = map.getMapOutput().getURL();
  4. To send a GET_FEATURES request, remove the dynamic layer and its workspace:
    Code:
    map.getLayers().remove(map.getLayers().getCount()-1);
    map.removeWorkspace(0);
  5. Call Map.refresh() again, this time the request is GET_FEATURES.
  6. The following is a complete sample code that can run with the 'SantaClara' service to add a new layer from 'sc_topoq24' shapefile that comes with the tutorial data. Click on the 'tract' layer to query features from this layer. GetFeatures.zip
