English
Error: Unable to copy PRJ for grid
Error Message
Executing GRIDCLIP at an ARC prompt causes "Unable to copy PRJ for <grid_output_name>".
Cause
Maximum and minimum bounding coordinates are switched.
Solution or Workaround
The <x1> <y1> should be the smaller of the coordinates and the <x2> <y2> should be the larger of the coordinates. Update these numbers as necessary.
