BUG
Incorrect result for RASTERMARKERSYMBOL when used with ArcMap Server
When using a RASTERMARKERSYMBOL acetate layer with an ArcMap Service the output image is incorrect.
Cause
1. The size of the RASTERMARKERSYMBOL has not been specified in the request.
2. The RASTERMARKERSYMBOL references a transparent GIF image.
Workaround
  1. Always specify the size of the RASTERMARKERSYMBOL for an ArcMap Service.
  2. If the ArcMap service requires RASTERMARKERSYMBOL transparency, use a non-transparent GIF image.
Article ID:000006690
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
