PROBLEM
The table window only shows empty column headers
After opening an existing ArcMap document and opening a table, only empty column headers are shown in the table window.
Cause
A problem occured when restoring the table appearance settings from the ArcMap document.
Solution or Workaround
Modifying a table appearance property resets the appearance settings. The table should then display properly.
  1. Click Options under the Tools menu.
  2. Click the Tables tab.
  3. Change a property. For example, if the font size it 8 point, retype 8 for the font size.
  4. Click OK and then re-open the table window.
Article ID:000006688
Software:
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
