English
Error: ArcGIS Schematics Designer: [Oracle][ODBC][Ora]ORA-00911: invalid character
Error Message
Creating a new document type in ArcGIS Schematics Designer using an ArcSDE for Oracle data source and applying a query results in:
Error:
Cause
The ArcSDE data source was created using a username that does not have sufficient permissions.
Solution or Workaround
Create the ArcSDE data source using the SDE user and password.
Refer to the following technical article, How To: Establish an ArcSDE connection using ArcGIS Schematics Designer, for directions.
